Slow Boosting - Wastegate Actuator?
MKIIITurbo88
23
Michigan
Car is a 88 MKIII, 7MGTE, stock CT26. It builds boost slowly, but once it reaches target boost, it holds steady without an issue. I am also running a HKS EVCIII
What would cause a slow boost condition? Car idles fine, and as stated, hold boost fine. It just takes forever for it to reach target boost. I cant even hit 5Psi in first gear...
Any Ideas?
Thanks!
8,900
What type of settings does the HKS unit have? Often a boost controller will raise the limit, but it still functions like a mechanical actuator, bleeding as it builds to prevent a spike. And make sure you have the lines hooked up right, and are not bleeding to atmosphere.
MKIIITurbo88
23
Michigan
The unit has a manual control, and a auto learn feature. Currently, I have it set to manual mode, but after reading the instructions, I am going to reset the unit, and try the auto learn mode once more. I had a line hooked up improperly previously, which may have skewed the boost curve saved in the controller.
Compton74;1850640 said:
There any other mods done to the car besides the boost controller.
It has a 3" TBE, Cold air, and that's it. 99.9% stocker.
OfnaRcR4;1850654 said:
Boost leak?
If it was a boost leak, wouldn't you think I would have a hard time holding consistent boost numbers?
hvyman;1850670 said:
Exhaust leak?
I do have a minor exhaust leak, but it is AFTER the turbo. Shouldn't be relevant.
91whitepack
71
slidell, louisiana
i would try to hook the wastegate actuator back to the turbo stock and eliminate the hks to see if it is the boost controller. If it still does it i would look elsewhere.
Numba1Stuna
361
Nampa, ID
Whitepack is exactly right. Take it out and if the issue persists, the problem is elsewhere. Isolation is a great troubleshooting step.
Sent from my LG-P999 using Tapatalk 2
