Slightly scary (and dangerous) Auto shifting 'problem'
Turbo Habanero
4,229
Tucson,AZ
MA70_Powa;1402450 said:
omg stop telling me to change my driving habits people!
just because I say I'm 'on boost' doesnt mean im flooring it or speeding etc!
I get boost from 2000rpm, even with light throttle. this means a lot of my driving - normal and 'spirited' is within my boost range.
As I have said, this problem occurs randomly. It's even happened to me while going around 50kph and driving like a granny.
maybe I shouldve initially said 'while driving' rather than 'while on boost' ...
Or it happens while driving when you get boost?
This is the exact reason why I :love: Torsen style Diffs!
Even if they break traction the car travels in a straight line and doesn't slide down the camber of the road.
First couple of times I got on mine hard I thought the clutch was slipping and had a bud stick his head out the window and watch the rear tire ;)
Bri7man
"Yeah! Take the lemons.."
Jul 17, 2009
580
Torrance, CA
What type of lsd do our cars some with stock in comparison to the Torsen?
BTW IJ I'm in love with how your car handles on that dirt road in your videos.
Turbo Habanero
4,229
Tucson,AZ
Jeff Lange;1401224 said:
Let me answer that question for you.
USA/Canada Destination:
86.5 - 92 N/A = 4.30:1 (USA: LSD Optional, Canada: LSD Standard) (Open Axle Code: G284; LSD Axle Code: G285)
87-88 Turbo = 3.91:1 LSD Standard (Axle Code G315)
89-92 Turbo = 3.73:1 LSD Standard (Axle Code G305)
Japan JZA70:
1JZ-GTE Automatic = 3.91:1 (Torsen LSD Optional) (Open Axle Code: G314; LSD Axle Code: G319)
1JZ-GTE Manual = 4.10:1 (Torsen LSD Optional) (Open Axle Code: G294; LSD Axle Code: G299)
Jeff
Bri7man
Jul 17, 2009
580
Torrance, CA
Do you have the multiplate style in your car when you made the video on teh dirt road? How is it installing these?
No that's a Torsen in the car (well a Detroit TruTrac the American version of the Torsen).
Install is a bolt in of you swap the entire pumpkin, T1 Torsens don't cope too well with shock loads but having said that I ran 500+rwhp through mine for years before I swapped it out for the 9".
MA70_Powa
Boost Addict
Jun 17, 2007
180
Tasmania
Well I'd love to have a torsen, but a) they cost a lot and b) I can't find one :(
how much do you think it would be to get mine rebuilt IJ? If it needs to be done, that is.
Not sure if anyone in Tassie would do it either. No-one I've called yet does it. People down here suck, lol.
oh and habanero, I have noticed it happening a few times when boost is building, but I'm too busy watching the road to check at what boost level (<--super late edit) it most commonly happens :p
I know there's a couple of bearings in them that are a freak Toyota size so the only available ones here are Genuine so cost plenty....
Might pay you to have a "kit" sent from the USA and get someone locally to rebuild it.
Turbo Habanero
4,229
Tucson,AZ
I was jjust thinking if it only happens in boost then your putting to much power on your Diff hints why its giving out....possible
4
IJ: I've heard of people pulling the cable all the way tight and just holding it that way, I thought that would cause these issues?
Honestly, I don't see a reason to ever have an auto tranny bark gears...
MA70_Powa
Boost Addict
Jun 17, 2007
180
Tasmania
Yea my diff could be dying, as It is now 23 years old and knowing how the rest of my car was when I got it I wouldnt be surprised if it's never had a fluid change in its life.
