Slight Miss
JDMMA70
2,550
Houston
Before anyone says search I did and notice everyone elses problem was different.
Here's mine.
I've had this slight miss before and after a friend and I replaced the CPS and timed the car. I replaced spark plug wires (NGK Plug Wires), NGK Coppers gapped to .031, New IC Hoses (Soon to be replaced with Hardpipes), and a new TPS set correctly. Now my slight miss is noticible from time to time, only happens when the car is idling (when im at a stop light for example) but when im driving the miss isn't even noticible. I checked the coils and they all checked out fine. Plug wires are new barely any miles on them. The timing was set to 10' so im not sure where else to look. All my vacuum lines are set and secure. Like I said it isn't noticible when im actually driving the car, I just figured it was time to solve the problem.
Any ideas?
Thanks
~JDMMA70
JDMMA70
2,550
Houston
You can feel it inside the car when its idling it will do it a few times, then it'll be gone from anywhere to 5-12-20 seconds and then come back again. Its not noticible to the point the exhaust starts popping, but its noticible to where the engine shakes.
JDMMA70
2,550
Houston
bountykilla0118;974050 said:
how much vac in HG's while you idle?
Im not sure I quite understand your question? HG's? For a second I thought you were refering to mmHg.
Please elaborate im sort of a n00b.
Thanks
~JDMMA70
wardog
R.G.V WARDOG
Jan 19, 2006
564
ALTON, TX
Do you have an aftermarket Boost Guage? What he ment the vaccum that the aftermarket guage shows while Idling. A good vaccum is 18-22, Im here in houston were do you live. Im by 59 and 10.
JDMMA70
2,550
Houston
Oh, no I havent purchased and Aftermarket boost guage yet, I will soon however as soon as funds permit. Im by I-10 and Fry Road. Pretty much i live in Katy.
wardog
R.G.V WARDOG
Jan 19, 2006
564
ALTON, TX
I have a SUNPRO Boost guage from autozone just $15 until i can get money for a PROSPORT set of guages. I migh head to Katy later on today to go visit some family ill let you know and we can hook up my guage to your cat to check the vaccum.
JDMMA70
2,550
Houston
Thatd be cool let me know i should be home all day, but yeah let me know ahead of time so that i am home.
ATL88Supra
The Asshole
Jun 22, 2007
497
Atlanta, Georgia, United States
is the overall preformence of the car effected ? mine has the shakes sometimes but alot of cars and trucks do that
if its not effecting on road preformence i wouled not really worry about it
i really need a soundbit of the motor runing
bountykilla0118
In Pursuit of 500rwhp
Jul 16, 2005
1,088
Atlanta GA
Naw he should worry about it b/c it means there is a problem. Don’t be the typical MKIII owner..... Meaning spend the less time, money and effort on maintenance but spend more money, time and effort in performance. Getting the car to run right should be 1st.
Its a simple thing but you just need spend a little time to figure it out....
ATL88Supra
The Asshole
Jun 22, 2007
497
i have a 3.5" straght from turbo back and when i have had the slightest missfire i always here it, are you sure its a misfire a sound bit of your motor would help me tell you whats wrong, but from the information provided im kinda like wtf ? sorry if i seem a bit noobish or even as killa said "Don’t be the typical MKIII owner" a vacume leak will not cause the motor to shake it woull cause RPM drops and wont idle,
so whay dont we start at square one
when was the last time the car ran "Smooth"
when was the last oil change?
when did you replace the air filter?
when did you check your AFM to make sure it was working within specs
basic stuff like this..
JDMMA70
2,550
Houston
Alright Q&A always works best.
Cant recall it did this when my dad first picked up the car back in June '07
I changed the oil a month after i had the car. I didnt drive it much between July '07 until March 24th 2008 when i officially started driving the car after getting the kinks worked out.
Replaced the Air-Filter in December of '07
Checked the AFM as per TSRM and even have a used/better AFM Honeycomb thing.
billwert
169
Naylor
I'm having same problems you are. Was told to change brand of spark plugs. I still have the same problem. Thinking about going back to the type of spark plugs that came out of it when it was running good instead of NGK's. Good Luck.
JDMMA70
2,550
Houston
I had Densos in mine originally but i never started it up only my dad did. I replaced them with NGK coppers when i did the oil change. Now i can say the cars miss wasnt THAT apparent until i changed the plugs as my densos were gapped to .041 i guess that was to match the ridiculous timing.
JDMMA70
2,550
Houston
twinturbozs;975485 said:
check your timing. I had a miss when i was set at 10 degrees, but lowering it to 5 degrees minimize it.
Wouldn't lowering it 5' lower my idle to like 500rpms?
ATL88Supra
The Asshole
Jun 22, 2007
497
correct, time it per tsrm, also, this my be a long shot, but test out your ignigher (wow miss speeled the shit out of that)
clean your injectors too, never know
as for more Q/A
how long as it been like this ? ( missing )
did the last owner have head work done to it ?
