slave cylinder broken.
antigram
breda
I can't put the car in gear when the engine is running. I can put the car in gear when the engine is off though. I have already replaced my master cylinder and that had no effect, so i guess its the slave cylinder thats giving me a hard time. Is there any place i could buy a new slave cylinder that fits the r154 other than toyota?
Suprapowaz!(2)
2,870
San Antonio, Tx.
First off, have you seen if the slave cylinder is operating properly? Raise & support car, have friend push clutch pedal in a out, remove inspection cover and see if it's moving in or out. Bleed the system properly?
Has you car been working fine until now, or have you developed this problem after and clutch disc and pressure plate change?
