sick of my auto tranny
boosted2085
I was spoolin :(
Mar 1, 2009
218
houston,tx
well im tired of my auto tranny...ive been looking into swapping to a r154 but funds are kinda short so i might settle for a w58(not saying thats a bad thing)...i found one at the junkyard for 300$...so i have some quetions for those who run the w58 tranny(and yes i SEARCHED but i never found a clear answer
1)whats the max hp i can push the w58 tranny of course with a good clutch.
2)can i use the same differential from my auto?..i know the driveshafts out of the question because its shorter.
3)what else do i need for the swap?(ecu,override neutral switch,reverse lights..etc...
im looking for 350-400 hp safely,or just wait for the r154?
gtsfirefighter
SM Expert on White trash
Sep 26, 2006
2,965
I'll bet you could find one cheaper through a member here. I'd look around before buying the junkyard one. Lots of supra resources in Houston.
The diffs are same on both auto and 5 speed. I believe you can use the same driveshaft with a W58 but not with an R154.
As for as your other questions, there's been some fairly recent threads about this. Search the technical forum and you'll find your answers...and then some.
boosted2085
I was spoolin :(
Mar 1, 2009
218
houston,tx
Ive searched and some said 300hp max some said 400max...i found a place in houston but they want about 500$ for tranny and a grand for the whole setup without clutch,ecu,driveshaft...
T-MA71
Always broken down member
Mar 16, 2008
213
Nashua, NH
I'm running a W58 on the turbo. It can handle 15psi easily on a new oem clutch (Or close to 15psi because i somtimes hit fuel cut). but the W58 isn't bad at all.
I also was looking at an R154 at a junkyard and they want 400 for it. I said eff it and kept the W58. I can find a parts car with an engine and tranny for $600 in my area. So i'm just waiting patiently for one to show up now.
boosted2085
I was spoolin :(
Mar 1, 2009
218
houston,tx
Well i got a w58 setup for 200$..driveshaft,tranny,clutch slave,clutch resevior,lines,brake pedal....now my question is...
1) do i need the manual ecu...or somehow override the neutral safety switch...
2)what about the sensor or switch on the clutch pedal do i need it and how would i wire the auto ecu to it if i do need it...
92TealSupra
Supramania's Parts Man
Sep 2, 2008
1,584
Great Lakes State
The W58 for 300.00 to me would be top dollar. I have seen them go for as little as 125.00, I would suggest if you are patient getting a broken supra with a r154. I paid 500.00 for my '88 turbo with a r154. I sold all the parts I didn't need, and have around 1200.00 + parts in which id o need. I also went and bought a r154 for 425.00, just sold it though because the 1jz I ordered for my swap has one.
boosted2085
I was spoolin :(
Mar 1, 2009
218
houston,tx
well i got the w58 tranny for 129$..but with all the items came out to a little under 200$...now i got to decide on a clutch,at least a stage 3,i seen the act stge 4 from dm has anyone used that?..or if someone has better opinion with my supporting mods and that tranny...
boosted2085
I was spoolin :(
Mar 1, 2009
218
houston,tx
1st pic)well im about to put the clutch pedal in but these two sensors i need to know do i need them with an auto ecu,if i do what are they called
2nd pic)instead of putting the brake pedal from the standard car i just cut the pedal to fit the rubber piece,should have i did that?...
Davismj711
PA Mountain Supra
Boosted
When I did my swap I put the 2 brake pedals side by side. Other than the Auto having the wider pedal pad there was no difference in the length or bend of the arm, your fine there.
On the 2 switches, you can use the lower one for your neutral start wires extended from the original neutral start switch on the Auto Tranny. It is up to you if you have cruise and or do not wish for the car to start w/o the clutch engaged.
boosted2085
I was spoolin :(
Mar 1, 2009
218
houston,tx
thanks i forgot you posted that for me...ok that clears it for me..one more dumb question.. when i push that clutch pedal foward it stays forward,doesnt retract,is it supposed to do that and the presure from the master cylinder pushes it back or i got a messed up pedal?
Guyana00
Droppin that JZ in soon!
Apr 18, 2007
1,208
Brampton, ON
Let us know how it goes, once it's done that pdeal should be coming back. Also you're going to need the flywheel, I didn't see it in the list of parts you got. Sounds like you may have one but I'm just telling you.
boosted2085
I was spoolin :(
Mar 1, 2009
218
houston,tx
i forgot to put that in there..yes i have a resurfaced flywheel and arp flywheel bolt....ill post what ive done to help anyone out
