show us your swap
destrux
1,183
10
PA
GrimJack;1793171 said:
Have you considered getting a *slightly* smaller turbo and a quick spool unit? Brad got a 500 rpm faster spool on a GT35 with just that. Nice looking curve, too, it just expanded the entire power band to 500 rpm sooner.
The HY35 is about the same wheel sizes as a GT3076R (it's the closest thing garrett sells anyway). So the GT3071R is just one step down. If I got the GT3071R I'd probably get it with the divided .78 a/r T3 housing, which should spool fast enough even without the QS valve (with it I'd be worried about surge). I'm just not sure if it's worth spending $1400 on a turbo when I'm not sure how much better it would be than a $150 set of used stock turbos.
te72
Classifieds Moderator
6,621
9
WHYoming
pat1;1793095 said:
Mine isn't a Supra, Its a 76 Datsun 280z
So jealous, for so many reasons... why do you have SOOOOO much engine bay room? Even the L28 wasn't filling that was it?
IJ.;1793174 said:
Is eeet done yet? I haven't followed your thread in far too long.
gurley0916;1793184 said:
And then there's this fucking guy... couldn't even be bothered to close up the old harness hole. :rolleyes:
Showoff. ;)
525gte
450
hoquiam
empera;1793244 said:
doesn't count....not done. Along with your other 10 projects :p
how is it you had a 850 motor laying around?? is that a supra its going into.? when u get closer i may be able to help i learned alot about the bmw electronics during my swap, had to understand it it get the toyota working properly.. the mostimportant thing was that bmw switchs grounds via ecu, instead of switched power to relays
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
Still in progress:
Waiting on a wastegate part from HKS Japan. In the meantime, I will be cleaning up the body a lot. The motor will be coming out soon, then the blocksanding and coating comes.
f00g00
586
Kuwait
Another dirty engine bay. Last pic after a quick clean, really need to polish the piping but on the car would be difficult.
