sheedy126;1938278 said:never got full spool unfortunately before my turbo went, so i'll never know with the stock hx35 wheel.
i did get 10lbs around 3200 ish though if that helps you any. its a faster spooling turbo than i thought it was going to be, thats for sure.
QUOTE]
To give you guys a comparison I make 10psi at 4357rpm. 18psi at 4807rpm. Verified by MAP ECU log. I have a Garrett 60 trim w/.70 hotside. I wish I had an HX35.
sheedy126;1939193 said:Aaaaand in for the third time. This time ready for some good power
Should be running tomorrow
Sent from my PC36100 using Tapatalk 2
IndigoMKII;1941788 said:Update?
Did Aaron rebuild your turbo when you purchased the 62mm billet wheel upgrade?
