Sheedy Built Supra
sheedy126
Boost Addict
Apr 30, 2012
716
kennewick
well, ill start off with when i bought this car, i didnt know too much about it and what i was getting into but has been a great experience for me.
i started off looking for a cheap car with good gas mileage on craigslist when i stumbled upon a car i couldn't go without.
it looked like a nice 2door sports car that had some motor to back it up.
two days later, in april this year, i went to Cheney to pick up this awesome car.
a few things i had to fix before i drove it were the brakes, which were locked and filled with petroleum (said the guy i bought it from), and a clutch. i threw in an Aisin HD r154 clutch.
i drove the car to work maybe 3 times when i came home one day getting on it a little. tons of white smoke everywhere and had no power. there goes the HG :icon_evil
so let the building begin, thanks to my dad and CajunKenny for helping me along the way
i now have the motor rebuilt and installed in the car, but ill post some pictures on the way it got there.
between my toyota crawler and supra, they both keep me really busy
heres how i got the car from a kid in Cheney
pulling the motor/tearing it down
sheedy126
Boost Addict
Apr 30, 2012
716
kennewick
once the motor was disassembled i sent it off the the machine shop to get some work done.
cylinders honed, 3angle valve job, block/timing cover decked, head resurfaced, crank polished and everything cleaned. looks nice and fresh..
while it was there i had them throw in small block v8 chevy double valve springs (just the inner spring i think it was)
began painting everything
sheedy126
Boost Addict
Apr 30, 2012
716
kennewick
started putting the bottom end together and plastigauged the crank and rod bearings
once the bottom end was put together i got some schweet parts in the mail...
custom grind 272 Snyder racing re-grind cams. these things are awesome!
Titan 2.0 MHG from suprastore
started putting the head and cams in. man those valves are fun to shim with no toyota SST :nono:
sheedy126
Boost Addict
Apr 30, 2012
716
kennewick
started putting on the manifolds and turbo along with some ARP head bolts
motor started going in right before we moved into town so i wasnt able to work on it for a couple weeks
heres a few pictures of the motor all put back together
broke the motor in and ran like a top with the stock fuel system and turbo
Recently installed a wally 255 fuel pump and drilled out the j tube.
Lexus AFM and RC 550cc injectors are installed. having a fuel pressure issue but will be on the road in no time.
next on the list is a JT62 turbo, have Maft pro just need to install it, and put the 89+ tail lights on. for some reason the PO had pre 89 tails and mirrors on?
supraguy@aol
Well-Known Member
Dec 30, 2005
4,245
47
Atlanta
I was waiting for someone to mention that.
It looks like he might have taken the pic prior to installing the cap? I hope?
sheedy126
Boost Addict
Apr 30, 2012
716
kennewick
ryansmith;1893050 said:
quite a clean looking car nice work on the motor
thanks!
its been fun building this motor up
yep, that pic is prior installing the cap hehe. im sure that motor wouldnt last too long setup sloppy :icon_bigg
sheedy126
Boost Addict
Apr 30, 2012
716
kennewick
dang phone pictures aren't the best
i believe they all fell around .0015''-.0017''
i cant remember 100% since i rebuilt the motor durring the summer but they were on the tighter side according to TSRM
got a few things done today before it got too cold out. started wiring up my Maft Pro system but waiting on my aem uego wideband to show up i ordered today so i can finish wiring it up
sheedy126
Boost Addict
Apr 30, 2012
716
kennewick
When I first bought the car I figured I would just daily drive it and keep it close tp stock HP.
But now every time I hear the turbo spool I think a few more HP wouldnt hurt :icon_bigg
I would say around the 400-450hp range with the turbo I'm picking up in a few months from a friend
BrandonW
1,300
N.J.
nice build, like the paint on the 3000 pipe and turbo
for some reason that hg looks weird to me
sheedy126
Boost Addict
Apr 30, 2012
716
kennewick
I'm not 100% on those numbers. Hopefully they are a little bigger than I think they are.
This is my first motor rebuild and has been a good learning experience for me,
Why might tighter clearances not allow for higher horsepower?
sheedy126
Boost Addict
Apr 30, 2012
716
kennewick
got some work done while i had some time off this weekend.
tried my had at polishing up some89+ brake lights for my car, i didnt like the pre 89 lights that came on it for some reason...
and threw some drag tires on just to see how they would look
hoping to get my wideband in the mail soon, get er wired up and tuned by my buddy soon!
