Setting up Maft pro need help finding Pigtails for the Map/Air temp sensor
Turbo Habanero
4,229
Tucson,AZ
So i'm installing a maft pro on the 7M and need help with what to do to wire in the Map sensor and Air temp sensor both are GM
My question is do i just need to find to pigtails for them and wire them in ?
And where can i find these pigtails ?
jonahs_supra
1,015
Lancaster, Ohio, United States
oh those are just simple gm style weather pack connectors
3 pin for gm 3 bar
If the IAT sensor looks like this
Then simply go to your local auto parts store and ask for the sensor harness
Then you WONT need the 2 pin weather pack connector, 2 female pins and 2 gromments
jonahs_supra
1,015
Place your IAT as far away from engine as possible but on cold side of intercooler piping
My location
Cant even see it :)
Originally i had my IAT mounted in 3000 pipe
But had major issues with heat soaking. 170 degree cruising on the highway on a 95 degree day
Relocation dropped atleast 60-70 degrees
