Hey guys, I am in the process of replacing my front seals, because I had oil on my belt and leaking out of the bottom weep hole. I read that those seal are supposed to leak some. Any truth to that? Would make sense. They did put a weep hole there, and it would keep the seal from cracking and wearing.
I also noticed oil seeping down the gasket for the timing casing and block. The pic shows you the gasket. Obvisouly it got tweaked when the previous installer put in together. My question is would that cause an oil leak? How do you keep it from doing that when installing?
Why I say is because when I done the hg I didnt do the silicone trick. (didn't know about it) Since I think my oil pump seal is leaking. I dont really know where that oil leak is coming from. I figured the gasket is there for a reason but....
I figured I would post some pics any how, cause I know this is a common problem.
