I actually kinda like the install of the aftermarket gauges.  Did you give any thought to replacing the speedo and tach?  I've often wondered if you could scrap all the factory gauges and install all aftermarket ones using the stock piece as a mounting template like you're doing.  However, I never really looked into the TSRM to see if this would cause problems with the ECU.
