SCHNEIDER RACING CAMS Regrinds
empera
Authorized Vendor
Philly.
Ok more questions.
anyone using a set of these? if so any problems, wat lift? duration? how much did you pay and what did u get? What type of springs are you using?...
thanks,
-emp.
holdbrooks
114
Alaslama
I have a set of the 288's sitting in my garage that i bought a while back, i had to do a bit of research on them to find out what they were but for the $200 i paid for the i think they will work out nicely. I got the cam card from the company an the specs are below
it will be some time until i can afford to buy the needed valve train components to run them but i will let you know when i do.
ENGINE
7MGTE
CAM GRIND NO.
288-82F
GROSS DURATION
INTAKE 288
EXHAUST 282
.050” DURATION
INTAKE 254
EXHAUST 248
LOBE LIFT
INTAKE .400"
EXHAUST .390"
VALVE TIMING AT .050
INTAKE OPENS
15 BTDC
INTAKE CLOSES
59 ABDC
EXHAUST OPENS
60 BBDC
EXHAUST CLOSES
8 ATDC
LOBE SEPARATION
114
DEGREE INTAKE TO
112
pics for size
ZFast300Z
Trouble
Dec 15, 2007
102
Wisconsin
I would actually measure both lift and duration of any Schneider regrinds. Numerous Z31 guys are having issues with their Schneider regrinds being significantly off in both lift and actual duration. It was bad enough in my case that I ended up going to new billet grinds.
holdbrooks
114
Alaslama
I mic'ed some lobes on mine and they where accurate but think I might check the rest now, thanks for the heads up.
ZFast300Z
Trouble
Dec 15, 2007
102
Wisconsin
Check the actual duration (not advertised duration) of that cams as this seemed to be where most buyers were reporting a problem. I'm not sure if it was just cams ground during a certain time frame or what, because I have used Schneider before and loved them.
Now I dont discriminate and I check ALL CAMS (both new and reground). I check all lobes before I ever degree or set-up valvetrains.
bmoss85
Permanently Banned Scammer
Apr 14, 2007
1,026
clemmons, nc
i agree this is always a good idea, ive seen a brand new cam be off. i know with the bigger companies if you call them and tell them whats going on they will replace it.
