Im interested in adding a small 1.5" oil pressure gauge to my engine bay for my new build. Would be nice to have one to glance at and make sure oil pressure is good. I really want the large low PSI range so I can look at the idle pressure of the 7m (will be around 10 PSI), so I don't want a gauge that loses precision with a higher max PSI. I know that oil pressure when cold can go above 60 PSI, so my question is if I used this gauge, would it be damaged when pressure exceeds 60 PSI?
http://www.toolmarts.com/interstate-pneumatics/IP-G2101-060.html
