SAFC2 vs NEO
sushi
31
Pottstown, PA
I've searched for this but I've found no comparisons. I'm looking for an AFC and I like the AFC NEO, but I see a lot of people trying to trade down to the SAFC2. It's mostly DSM guys, but is there some sort of problem with the NEOs?
1-2clutch-u
379
chi town and ohio
yea if you get a new one it will be fine but the firmware must be updated on the older neos. something about a glitch in the mapping for the karmen vortex. ill post a link if I find it but its documented.
sushi
31
Pottstown, PA
With your info I found out about it:
NEO reprogramming criteria:
1. Using NEO on Karman sensor car (Mitsubishi and some Toyotas)
2. Last five digits in the serial number is smaller than 13800
(sample serial number: AFC4 UN06-13726)
3. There is no Karman compatibility sticker on the back
You can call apexi tech support to find out more about where to send it to be reflashed.
ForcedTorque
Join the 92 Owners Group
Jul 11, 2005
6,099
Neo can make adustments every 50 RPM, where the SAFC2 is every 100. It also can control your V-Tach, and change colors.
Thank you for the reprogramming criteria. I need to check my serial while my car is down.
