SAFC Without Wideband
Brady
262
Bay Area
www.nbhq.net
I picked up a SAFC for relatively cheap, but I'm also pretty stock for the most part (mods listed in sig) I have no other fuel mods so I'm wondering if I should even bother keeping/installing the SAFC or if I should just sell it.
The main reason I would keep it is to tune out running rich in between shifts since my BOV is vented to atmosphere. And maybe gaining some mpg in 5th gear cruising
Any input is appreciated.
adampecush
Regular Supramaniac
May 11, 2006
2,118
Edmonton
sell it. if you want to get rid of the richness in between gears, re-route your BOV. At cruising, ECU adjustments will un-do any adjustments the AFC makes.
If you plan on upgrading injectors/afm, sure, keep it around; it won't do you much good stock though.
MK3Brent
Very expensive....
Aug 1, 2005
2,878
Greensboro and Greenville NC
I'd keep it, buy a wideband, then tune your WOT areas.
Re-route your BOV (you probably won't no matter what) until you go MAP.
In the meantime, just learn what adjustments do what and experiment.
supraguru05
Dec 16, 2005
737
louisville ky
i have a lc-1 and am going to install a safc 2 soon to tune my WOT points only. i dynoed the car and it was pig rich (around 10:1) even with everything stock. so keep it but get a wideband. you should be able to have it adjust only high throttle points so your cruise is still controlled by the stock ecu.
SySt
Burnsville, Minnesota
I agree on keeping it. You can get a digital guage and LC-1 setup from Innovate for about $230, so it's not too expensive. If all you are going to do is lean out the WOT you really won't need any other fuel modifications.
gaboonviper85
3,236
Northeast Philly
keep it so atleast you have it....never know when you may stumble on a lex afm, walboro fuel pump, 550 injectors and a fuel pressure regulator....
