S.A. supras metro (gay) blue 87 2jz build
S.A. supra
2,405
Buda, Texas
This Is a Craigslist find I picked it up for $800 with no engine, wire harness, or ecu. I initially tried to get someone to buy it but no one wanted to. So I bought it even though I already had two at home(sisters). I really need to stay off cl! I have owned four supras in the last six years, and I'm hoping this will be my last. Time to do it right!
My last car was a 89 with a 1j. The engine craped out on my so I was left with a car with no engine and a great interior. So since I like the way the metro blue 87 looked on the outside but not the blue interior with the checkered seats. I decided to get the best of both worlds, and put the grey interior in my gay blue car. The colors go well together, I don't know why Toyota didn't do it. I guess the had a lot of ugly blue material to get rid of.
I plan on building the car up to 600hp in two steps. First is getting the engine in and running then stage two will be cams, fuel system, and stand alone. I also have a lot of parts that I need for my build from my 1j. That should make things easier for me.
Parts I have so far are. (Running total for those thinking about 2j swap)
$6934 including the car. The car was $800. Parts and supplies $6134
0. Car $800
1. 2jz engine (from jdmsource.com) $2135 shipped to me
2. Cobra rims (craigslist) $300
3. Brake master cylinder (Autozone) $55
4. Clutch master cylinder (Autozone) $45
5. Slave cylinder (Autozone) $30
6. Fidanza light weight fw. http://www.clutchflywheel.com/ $330
7. Act xtreme 6 puck sprung kit http://www.clutchflywheel.com/ $555
8. 6 injector and 6 coil pack clips http://www.bmotorsports.com/ $85
9. Bell housing. (Champion toyota supraforums) $300
10. Toyota gasket set. (Champion toyota supraforums) $390
11. Toyota water pump. (Champion toyota supraforums) $120
12. Toyota oil pump. (Champion toyota supraforums) $160
13. EBay log manifold. (Ebay) $170
14. 38mm to 44mm wg adapter. (ebay) $25
15. turbo down pipe kit (driftmotion.com) $135
16. 1jz flywheel bolts (driftmotion.com) $30
17. Gates Racing Timing Belt for 2JZ (driftmotion.com) $73
18. Marlin Crawler Shifter Socket R154 (driftmotion.com) $6
19. Shifter Bushing For R154 (driftmotion.com) $12
20. R154 Transmission Output Shaft Seal (driftmotion.com) $10
21. Redline MT90 Manual Transmission Fluid (driftmotion.com) $11
22. Split Loom 1.25 inch (driftmotion.com) $12
23. R154 Input Shaft Seal (driftmotion.com) $10
24. Aem Tru boost boost controller (Ebay) $255
25. r154 front bearing retainer (toyota oem parts world) $65
26. Crank position sensor (toyota oem parts world) $105
27. lo-tek 2 gauge pillar pod (gaugepods) $64
28. Timing belt tension (autozone). $45
29. Clutch Release Hub Kit R154. (DM) $25
30. R154 Factory Toyota Transmission Mount for MK3 Supra (DM) $69
31. Walbro Fuel Pump For 84-92 Supra (DM) $93
32. R154 Fork Support with Spring (DM) $47
33. Clutch fork (member) $40
34. Oval alt 3 pin connector (DM) $7
35. Denso Norrow Band o2 sensor screw type (DM) $53
36. 3 inch exhaust gasket (DM) $7
37. SS 3 inch exhaust flange (DM) $15
38. V-band 3 inch exhaust kit (DM) $30
39. 2jzgte valve cover ventalation hoses (DM) $17
40. Battery tie down (DM) $18
41. 12 mod supplies (radio shack) $45
42. Intercooler Supplies couplers, t clamps, (siliconeintakes.com) $90
43. Toyota Fuel filter (toyota dealer) $25
44. Toyota Oil filter (toyota dealer) $20
45. 2 cam position sensors. (DM). $180
46. Two clips for the cam sensors. $12
47. Get the down pipe mated to the exhaust. $100
I tried selling it once but no takers ( I was kinda happy about that) this is her at home cleaned up.
I need to get pics of it with the grey interior..... But here are some of the engine that jdmsource sent me. actual pics of the engine they will be shipping.
satx88supra
388
San Antonio
Nice!!!! Don't forget to keep a list of what you need so yo bestest brutha n law can just shop and swap when he's ready. BTW....is that the blue interior or am I ruining yo build by letting it slip you changed it to grey?!
S.A. supra
2,405
Buda, Texas
Nope, I just don't have any pics of the grey interior. I'll get some this weekend, I'm gonna pull it out of the garage put those wheels on and take pics of the interior.
Looks like a nice engine from the outside. Hopefully the inside is just as clean. Cant wait to see more.
You stay with the twins or going single?
S.A. supra
2,405
Buda, Texas
Yeah, the first thing I'm gonna do when I get it is pull off the valve covers and see what I'm working with.
Going single. I have a 67mm dm turbo from my 1j.
S.A. supra
2,405
Buda, Texas
Pulled it out today and slapped the rims on, and took some pics of the interior. Rims look nice. After I get the right size tires and drop it a little is should look really nice. Here are pics.
S.A. supra
2,405
Buda, Texas
Suprapowaz!(2);1736692 said:
Looks good. That interior color looks good with the ghey blue. I'll be following this build thread.
Thanks, you need a thread.
satx88supra;1736720 said:
Rims look nice Mike!!
Thanks, they will have to do for now. Better then the saw blades that's for sure.
S.A. supra
2,405
Buda, Texas
Thanks, yeah I don't know why they put all that blue in there from the factory. I was unsure if the grey would go, but it turned out looking better than I thought it would.
S.A. supra
2,405
Buda, Texas
I'm looking at aem v2. But that's gonna be down the road a bit.
I finally got my tracking number for the engine. It should be here next week. I'm in the process of installing my new brake and clutch master cylinders. Also the non abs brake lines. I should have some pics up later of the engine bay cleaned up. I just got a quote for bellhousing, flywheel, gaskets set , oil pump, and water pump from champion Toyota on supra forums. They came in $200 cheaper then driftmotion. I'll put that money toward the act xtreme 6 puck clutch kit. I'm still not sure where in gonna get that from. I still have to check prices for that. I'll pass on where and what I paid for parts. I'm a cheap ass and will be looking for the bets deal.
S.A. supra
2,405
Buda, Texas
I got the engine the other day looks good. Time to start wiring. For the guys that have gone 2j, did you do your own wiring? And if so what sources did you use?
S.A. supra
2,405
Buda, Texas
slowmedown;1743972 said:
hey another gay blue JZ swap! good luck man
Thanks man, are you going 2j?
UPDATE
Haven't done much, cleaned up the engine bay. Painted the brake booster and installed non abs lines, new clutch cylinder, and brake master cylinder. right now I am in the process of wiring up my aristo harness to my supra. I turned my daughters room into my harness work shop. Tomorrow i will be ordering my oil pump, water pump, flywheel, bell housing and gasket set from champion Toyota. I also bought a hand held media blaster from harbor freight. i will be cleaning the parts i pull off the engine as i swap in gaskets all around. Here are some pics of my progress
Some of my harness mess.
Oh yeah I did this a while back wanted more sound then just the 4 speakers that they had on the 87 model.
