rust in spare tire well.
Supraguy7M
7m forever!
Jan 9, 2013
198
bennington vermont
I have minor rust in my spare tire well. Its thru in a few places. The thing I would like to know is can I cut the whole spare well out, and make it a "flat trunk"? Would I be able to use my factory gas tank? If not then ill fix the rust. I didn't know if seeing as the tank sits up against the underside of the spare tire well, if it was even possible. I don't wanna go fuel cell though.
Thanks, any ideas appreciated,
-Matt
mikejza70
65
mn
I cut and welded the tire well flat so I could relocate my battery down there. The fuel tank wont get in the way.
mikejza70
65
mn
The tank will not move around. There are two straps w/ bolts holding it up.
That 'nipple' and 'lump' in the tire well can be cut and welded flat without any negative outcomes. Unless you actually use the spare wheel..
But if you do decide to cut and weld be sure to remove your fuel tank.
