hey
so basically i have a problem, not sure what it is. so when the car is cold or sat for at least 2-3 hours.
when i start it up it idles and my a/f ratio is fine 14.7 then it goes rich because of the cold start injector (about 5degrees in canada). durigng this time when i drive it its perfectly normal-fluctuating back and forth around 14.7.
then when it warms up say about 20 minuites into the drive it will suddenly go rich to 11.5 or richer and thats during cruise. at idle itl be about 13.5. but i dont see it fluctuating like it does when its running fine.
it use to have code 31 (resoldered from safc wiring) and it never came up again
came up code 21 after a while-soldered to the shielded wire (fixed and wired it correctly) never came up again.
resistance of the oxygen sensor is 0.03ohms- but dosent set the code
anyone have any ideas what it could be?
