Im pretty sure i know the answer to my own question but id like a little reasurrence before i go on a scavenger in my engine bay. Last night i installed 550cc injectors in my car. Car runs great under normal driving. However, at a stop sign/light when i start to move again the car goes above 20 a/f ratio on the wideband and the car bogs for about 200 rpm then quickly returns to a 14.5 a/f ratio for normal cruising. Also when im cruising and try to give it more gas, it does the same thing. When i go to wot.....it does it but i will get a 11.5 a/f ratio when boosting. Boost was at 13 psi....it made it all the way there.
So im assuming this is a boost leak due to unmetered air getting in when you give it more throttle but i just wanted to be sure. All Ic pipes are tight but i will double check. It may be the 3000 pipe/ throttle body coupler.
*EDIT***** There is a small crack in the rubber hose in the pCV and in the throttle body coupler.
Im assuming this is now my problem. Do I have to go to toyota for these parts or can i just get a vacuum hose and then a 4ply coupler for the tb?
Maft is set for 550cc injectors. Idle set at -15% which makes idle around 14.5-15 a/f ratio.
Any input would be great
