Running hotter than normal
Pokey2301
204
Spangdahlem, Germany
Ok, I have been driving my car in the city traffic in Tucson with no problems. She runs normal temp all the time, but when I get on the interstate, the temp goes up to a 1/4 in away from hot and stays there. Then I go back to city traffic and the needle goes back to normal. Why is she doing this?
Now the background on her
3 in bic DDP
550cc inj
Lex afm
Auto to 5 sp swap
And she is a 1990 model
Headgasket was replaced a year ago
She isn't leaking coolant and the oil and coolant aren't mixing.
Any suggestions?
Thanks Jeff
chris_2jz
141
tampa
Sounds like my issue. Mines turned out to be my waterpump (i have yet to replace it) but I can see it leaking down on to the alternator. As soon as I replace it and see my results ill update you
Sent from my SGH-T959 using Tapatalk
speedfreak
SCruzer
May 16, 2006
109
santa cruz, ca.
ya is your fan clutch engaging at the warmer temps? or maybe backwards thermostat? remove the jiggle valve from thermostat.... i have a 160F thermostat if you want
Pokey2301
204
Fan clutch is fine, she blows as loud as she can.
Water pump works fine as far as I know and no leaks.
It does the same wether the thermostat is in or out.
And no obstructions or clogs.
Fan is only useful at slower speeds.
Jiggle valve cutting is only for easier filling.
Both rad hoses the same temp?
