running 10psi
futeki_supra
295
lincoln, NE
I know this has been covered alot before but I searched "10psi" and got like 2 results...
I just got a nice ball and springs mbc and turned it up to 10psi, and wow I am happy with it,
I am wondering if this isnt too much,
my mods are.
2.5" - 3" dp, custom 3" straight exhaust, k&n fipk.
before I installed any parts I would get a steady 6.5psi, and then after the i&e,
I would get around 8psi, and on cooler days I could get 9psi, and everything seemed fine, I just wanted some reasurance.
( I always run 91oct. )
lagged
1991 1JZ
new rochelle
it SHOULD be ok assuming your injectors and fuel pump are up to par.
id replace your fuel pump though as i had one crap out on me at 10psi and cost me a head gasket...
oscolivar1
Supraism
Feb 8, 2006
1,000
Virginia beach
Yes an Mk4 fuel pump can fit .
IIRC they are like $200-$300 depending on where you live.
The mk4 pump is better than the walbro IMO, but the walbro is a great unit as well.
If you have the money I'd spend it on an Mk4 pump
Oct 11, 2005
3,821
26
Thousand Oaks, CA
This is an upgrade I've been looking into a little. The MKIV Turbo pump (Denso 195130-1020) will support 550CC injectors as long as you can get 13V to the pump terminals.
The supra pump draws double the current relative to a Walbro GSS341 for the same flow and so the ability of the stock MKIII wiring to support the pump is a concern that I have. I like the fact that the MKIV pump passes Toyota QA, so it is likely to be reliable over the long haul. The Walbro line is a little questionable in that regard, though I don't see a lot of complaints about their reliability. The Walbro GSS341 draws about half as much current (at 13.5 V, 8A @ 43 psi, 10A @ 70 psi) as the Supra fuel pump.
Lots of good info here
http://www.stealth316.com/2-fuelpumpguide.htm
