Runnin a ffim on stock ecu
Zrain25
639
Pelham,New Hampshire
Ok so I'm going to be running a ffim with a q45 tb and stock ecu until the motor is broken in then I will put in my aem v2 I will be still using the iacv.
Few question. Q45 tb does It need coolant lines going to it?
Stock tb has that little dash pot that doesn't allow the tb to slam shut do I need to fab that up to the q45.
No and no.
But why don't you just break the engine in with the v2?
Your part throttle response is going to suck with a bigger throttle and stock Ecu.
adampecush
Regular Supramaniac
May 11, 2006
2,118
Edmonton
Q45 TB will cause the car to be jerky at low speeds. Don't run coolant lines as the TB has an internal thermostat to crack the throttle plate when cold to cause the car to idle up. The ISCV will take care of this function.
