RPM meter not working.. (after engine swap)
scotty
476
Norway
scottnicholas.net
Hey.
My original RPM meter is not working after the engine swap. GE to GTE, so engine harness/ECU is changed.
Does anyone know what can be causing it?
Thanks,
Scott
deabionni
The Lurker
Sep 16, 2007
431
Kalkaska, MI
gamer565;1543620 said:
You need to get a GTE cluster
Actually, you don't need the whole cluster; just the GTE tach will do. Once you get your N/A cluster apart, the GTE tach is plug and play in the N/A cluster.
mkiiichip
1,434
WI
this is what we call a cluster
and a tach (tachometer) is a rpm meter
scotty
476
Norway
scottnicholas.net
So I can just swap the tach and keep the rest the same? Will the speedometer work(as the rpm meter doesn't)? (got no driveshaft yet så haven't had any chance to check)
Is it easy/hard to take the cluster apart and change the tach?
7mslider
70
shelbyville
just so you know, you probably won't be able to just throw a full turbo cluster in if you didn't swap the dash harness. the plugs on the back of the na and turbo clusters are wired different. it's easiest to grab a used tach off a turbo and put it in your na cluster....two or three screws, super easy
---------- Post added at 01:23 PM ---------- Previous post was at 01:21 PM ----------
oh yeah, and yes the speedo will still work, as it's mechanical
mkiiichip
1,434
WI
once you get the cluster out you will notice the spedo is driven by a cable, and should work if you have one of these pluged into the rear of the trans
once you have all the screws out of the cluster, it is still kinda held in there by the speedo cable, just wiggle and pull. other than that piece of cake.
