Ron R. FFI long runner style and your alternator...
Reign_Maker
Has cheezberger
Aug 31, 2005
5,767
Florida
Can someone post a pic of their alternator installed with a Ron R ffi long runner style? I was looking at it the other day when putting it together, and I cant seem to figure out how to tighten the tension for the belt... Also, does the stock belt work, or will I need a different size?
Thanks,
Jake
dbsupra90
toonar
indiucky
does this help?
tookwik4u89
Red T-shirt
Apr 6, 2005
2,008
Rockford, IL
From Ron's thread in misc vendor section:
Update, 6-18-06
Alternator BELT Part numbers:
For long runner: Dayco polycog, 5050480
For short runner: Goodyear Gatorback, 4050450
Update, 6-23-06
Making the throttle cable:
Page 5 of this thread, post #43
Reign_Maker
Has cheezberger
Aug 31, 2005
5,767
Florida
DB, thanks, Im hopin maybe you have a shot of it out of the car? Also, do you have a hi res shot you can email me?
Ken, thanks for the info, I guess I COULD HAVE looked there, hehehee...
mattsplat72
is sofa king
Jan 17, 2006
1,738
Well speaking of the FFIM . When you install it has anyone just dropped the Alt. into the A/C compressor's old location I have removed mine and would like to put my Alt. down there . I think it would look much cleaner , also if I did locate it there could I use the factory a/c belt ?
tookwik4u89
Red T-shirt
Apr 6, 2005
2,008
Rockford, IL
You cant use the factory a/c belt, but it will look clean, and you can also lose the a/c idler on the timing cover, for even more CLEAN action.
Reign_Maker
Has cheezberger
Aug 31, 2005
5,767
Florida
You know I painted that thing and made it look all nice and shit, and then when I was putting my motor back together, I realized I didnt even need that thing anymore... hahaha
Db: that thing looks mammoth! But it does the job... Powder coat it, it'll look sweet!
tookwik4u89
Red T-shirt
Apr 6, 2005
2,008
Rockford, IL
LOL....sell it!
On a side note Jake.....you'll have to grind those timing cover bolts that held it on down about 1/4-3/8" because they bottom out. And I have bins of old toyota bolts and couldn't find any the right size, so I took the old ones to the grinder.
Reign_Maker
Has cheezberger
Aug 31, 2005
5,767
Florida
You know, I think I actually put the bolts in already, not the same ones, but I think I found ones that fit... Damn I cant remember now, I'll have to look when I get home...
Cya
628
Columbia, S.C>
I had to use a crow bar to bring the bottom of the alternator up. If it helps I didn't put the shim back on the ac bracket and the alternator tensioner will stay on after the alternator bolt is screwed back in.
Of I used the Dayco from advance auto.
