rod knock
lppro
LP Performance & off road
Apr 21, 2007
895
Sugar Hill, Georgia, United States
how do i know if i have rod knock? i can hear something.. but it isnt loud at all... and dosent sound consistant... how can i tell? im extreamley worried..... if it is knock how is it fixed?
s383mmber1
3,614
Somers New York
Using the search button will allow you to research recent threads with people who have similar problems.
In those threads, they discuss:
How to:
Diagnose rod knock
Tell if its rod knock
Fix rod knock
lppro
Apr 21, 2007
895
i searched couldent really find much... thats why i poasted a thread.. sooo can anyone help me? how do i tell if its rod knock? pleeeaasse? i just had the entire motor re built with eagle rods je pistons and chevette 77 berrings... everything was ballenced and stuff... new 5mm shimmed oil pump... and i ALLWAYS have great oil pressure... never goes below 18-19 psi... and around 40 when driveing... the motor only has 275 miles on it... running VERY rich.... because of a bad afm... (gettin a new one in a few days..)
lppro
Apr 21, 2007
895
ok so i can hear a faint tapping at idel.. when i rev a little the tapping gets louder then goes away... and it :seams: to be comming from the block)=...
this is a brand new FREAKIN motor!!!!!!
8,900
lppro said:
"Why are you worried about rod knock?"
because i own a 7m!! lol
You believe too much bullshit on the internet. Your engine may have been assembled wrong. If it is knocking after a rebuild. Did they use the correct select fit bearings?
Mr. Y
80 miles away from Kremlin
well, may be someone going to kill me for such advice... but my opinion is very simple... Can you afford to open engine and rechek all measurements, clearences etc? If yes, stop driving right now and take your engine aprat.
If no (and your shop can't do it for you) - forget it. Drive till it blows!
You see... I have 7M engine with 16 psi and it knocks... I was trying to figure this noise out... adjusted valves, replaced rod bearings, shimmed and checked oil pump... but it still knocks... not actually knocks very loud but ticks - for sure...
Moreover... I was _very_ afraid that I have rodknock... I was browsing Internet and found some vidoes of rodknocking 7M... Well it knocked much louder than mine... so, I decided to run till it blows... Yes, I hear _ something_ but I'm not sure that it's rodknock... since I replaced my rod bearings I almost sure it is not rodknock... And what about you?
And one more thing... you may think your engine "ticks" while your engine actually "knocks very loud" - it's all too subjective (sp?).
PS: sorry for my English.. I'm drinking vodka with medved right now ;-)
lppro
Apr 21, 2007
895
well i ordered the chevette 77 berrings for the 7mgte... thats all i know...
DonS1mpson
Black Supramacist.
Mar 19, 2006
674
England!
Lose crank pulley bolt?
I was almost sick when I heard my engine knocking, it turns out that it's (probably) just the crank pulley.
lppro
Apr 21, 2007
895
so i took a long screw driver and placed it to a few defferent places on the motor.. the intake mani. the head and the alt. and i put my ear to the end of the screw driver and i can clearley hear a tap and or knock...
mkIIIman089
Ohio
Hah, I love it!
Mr. Y - Your English is still better, even drunk, then many people who are supposed to speak it natively. ;)
lppro - You know that the spec for the crank pulley is 195 ft/lbs right? Putting a wrench on it isn't going to cut it.
