rod knock
dubsupra209
CENCAL SUPRAS
Mar 6, 2009
1,810
Merced, CA
your going to need..
-new rings and pistons
-maybe new rods (depending how bad it is)
-new oil pump
-new bearings
-arp studs
-mhg
now at the machine shop
-get head resurfaced 30ra or better
-head pressure tested
-valve job
-cranck checked
-rods checked
-maybe have your block bored depending on what you plan on doing
you might as well get gasket kit also....
thats all i can think of right now good luck..i went through the samething.
Why dont you check your oil level and what color it is and then give the guy a call if its good.
TooGoode
rediculous DD
Mar 1, 2007
549
Chandler, Arizona
wow. a 90 miles 7m rebuild. again. I hope it was due to no oil and not another noob rebuilding a 7m without proper procedures. Hope you get it all sorted out!
dubsupra209
CENCAL SUPRAS
Mar 6, 2009
1,810
Merced, CA
yea there seems to be a lot of those than they go 1j and part out half way through...
good luck hope you get everything figured out
