Well I got the engine pulled and on the stand, took the pan off to look at the carnage.
I immediately notice a nice size pile of metal shavings laying in the pan, what appeared to be A LOT of a bearing.
I start poppin rod caps off, went through 3 in no particular order, no damage yet. Get to piston #1 - its burned, but not bad at all. Im happy, I can fix this in no time.
Then I get to piston #3. Takes about 5-10 mins of convincing to get the rod cap off. And then I see it. The inside of the rod cap is jacked. Half bearing material still on the cap, def. scarred up. I attempt to take the bearing off, and its not having it. So I manage to BEND the bearing off of the crank, only to see that some of it is stuck to the crank (but, it can still be turned, thats not the bad part). I got the bearing off of the crank, but not off the other side of the connecting rod. The bearing definately spun, overlapped on the other bearing, and proceeded to WELD ITSELF TO THE OTHER BEARING AND CONNECTING ROD. Its totally fucked.
In the end, only #1 and #3 were damaged, the rest were totally fine. Looks like Im gonna have to break the entire engine down, pull the #3 piston and rod, replace the rod, have the crank turned and put all new bearings in.
I'll have some pics of the damage posted up soon, its terrible. Let this be another warning. CHECK YOUR FUCKIN OIL LEVEL.
