Replacing the transmission oil pan gasket
supraman508
496
maryland
Ok i just looked on the T.S.R.M to see the layout of the parts beyond the oil pan.i seen under the transmission oil pan their are 4 magnets,1 oil strainer.I don't know what the purpose for the magnets but while i'm in the process of replacing the gasket should i also replace the oil strainer as well? and last the two little gaskets?
supraman508
496
maryland
IJ.;1395482 said:
The Magnets catch any ferrous trash in the oil before it gets sucked into the strainer, yes always a good idea to replace the strainer while the pan's off.
Thanks IJ,hopefully this will prevent the transmission to freeze up,due to when sometimes when i put her in reverse to back out a parking space,it does'nt kick in for 3 or 4 sec.Then it decides to back up.
mickgarvey
135
Mukilteo, Wa
Also further note on the magnets i believe you can tell what parts are worn by the type of metal. IDK I just remember seeing this somewhere correct me if Im wrong.
