Replacement TPS
Txsupra
Professional Driver
Aug 23, 2008
239
Texas
Does anyone know of a different throttle position sensor that will fit/work on a turbo throttle body? I have a standalone so it doesnt have to work with the factory computer, nor does it need to be a 4 wire sensor. Prefer 3 wire.
CRE
7M-GE + MAFT Pro + T = :D
Oct 24, 2005
3,485
Denver, CO
Is there a reason the OEM won't do? The part which the TPS interfaces with is just screwed on, so I suppose that as long as the new TPS mounts to the existing mounting holes or if you build and adapter you could make almost any TPS work. I do not know of any direct bolt ons though; I suspect Jeff Lange may, if anyone.
Txsupra
Professional Driver
Aug 23, 2008
239
Texas
The OEM one will work but its sending some noise to my EMS. I imagine its because it turned 21 years old just a few days ago. Sure I could buy a new one from the dealer but I was just looking to find a different one. Ill go to the junk yards and see if I can find one to work with and or with out an adapter.
Thanks for the input, love the quote. He was hilarious
