I'll start out by saying before my head gasket "blew" (slightly), my compression was between 165-170.
It was starting to show symptoms of a BHG (air bubbling out when I take rad cap off, misfiring, running rough...), so I tore it apart and started the HG project.
Had the head machined, new valve seals. Scraped and sanded the block to a smooth surface. Put on a stock "stone" head gasket and torqued it down in 3 passes to 80ft/lbs with ARP studs.
Now I have put everything back together with all new gaskets everywhere, set my cams and crank pulley for the timing etc.
HERE is the problem! I did a compression test on 3 of the cylinders so far, and they are:
#1 - 80 PSI
#5 - 112 PSI
#6 - 90 PSI
I only have done those three cylinders, but, what would cause such low compression after all this work!?
I am sure I have forgot to mention a few things in this thread to make it easy for you guys to help me out. If so, just let me know/ask and I'll provide you as much info as I can.
#1 - 80 PSI
#5 - 112 PSI
#6 - 90 PSI
