Repainting Supra. Let's talk PAINT!
Supra469
495
Maryland
Hello all,
So that time has come for me to repaint my Supra. I don't that much about painting. so....here are my questions..
My paint code is: 8J3 Blue Metallic
I guess i'm budgeting approx. 3k for the paint job.
After toying with many different colors in my head I've decided that I may want to stick with the stock color but I sure would like to add some life to it with some depth and sheene.
I believe such paints have Pearl in them. So pearl is a must.
The MKII Supras had a very nice paint called: Medium Pearl Red. Such a beautiful sheen from that paint. So I was thinking maybe, Medium Pearl Blue. :)
Here's what I'd like to achieve once my car is repainted...
Firstly, I'd like to achieve at least the same level/quality of a completed paint job as the factory or better. Meaning, very little orange peel.
Would like to pull the motor out and have the engine bay sprayed as well....and while the motor's out paint the block, change out the clutch & flywheel, add a new oil pump, get to any other hoses that needs to be replaced and fix anything.
I would like all the door, trunk, fuel jams be painted as well.
Would like about 4-6 coats of clear.
Would like to replace the rear hatch mouldings while i'm at it also.
I'd like to keep all the factory decals that's been applied to the car. I like factory looking stock finish. Like those on the inside of the hood, the door jams etc.
Below the body mouling the paint has a "orange peeled" texture to it and I think it is that way because of being exposed to the elements, etc.?? Anyone ever noticed this??
I believe the paint shop should have a 'down draft' type booth to catch any over-sprays etc. And I guess the rest is up to the painter and his craft.
No runs or signs of over-spraying. Would like to have the parts pulled before painting.
Here are my questions:
Primer: Any special primers recommended are some better than others? Any Must have?
Paints: What brand is a good brand, I don't have to have the most expensive brand name, but quality is what i'm going for.
Clears: Again, what brand is a must have?
I've read where some people have put pearl in the clear, some put pearl in the paint etc. etc. What's the difference??
And what talking with a paint shop what types of questions I should ask so that I at least sound like I know what i'm talking about. hehe
And:
And for those of you who have successfully repainted your Supra, what were the problems enountered AFTER you began the process?? What to look out for?
THANKS!
Justin727
T-virus infected
Primer- Transtar makes a great primer. I suggest using flex primer and paint on the bumpers.. Anything flexible. If you get down to bare metal use a self etching primer for metal spots. I layed down 3 coats of primer followed by 1 coat sealer.
Paints- Alot of good paints out there. I used Chromabase made by dupont. Good paint along with PPG. Cheaper but descent paint is also made by the two companies.
Clears- I don't like to mix named brands so if you use a Dupont base use a dupont clear and the same goes with PPG. And anything after 3 coats of clear you're going to wanna wet sand before laying down additional coats or the clear will pop/break when hardened.
I didnt encounter any problems during my job. But there is more info out there I did not touch base on that other members and a little researching urself can come across. I didnt want to make a huge post hurting your eyes.
Hope all goes well!
Justin
figgie
Twin Cities, Minnesot-ah
the question to you is
what is your budget ;)
most expensive.. no. It is the prep work that will kill you.
PPG
Dupont
3M
House Of Kolor (my fav!)
out of those. HoK can be made to whatever color with whatever flakes (metallic, Pearls, Kandy's etc)
tissimo
Stock is boring :(
Melbourne, FL
leave it stock.. best mkiii blue color there is.. looks awesome fresh
