So I'm changing the side differential oil seals. I'm doing the one on the exhaust side now. How in the world do you remove the Side Gear Shaft on the differential? The whole axle itself is removed from it and all I need to do is "pop" it off. I've used a pry bar with a hammer tapping on it and it only budged a bit.
Here's the troublesome part.
Do you guys know of any tricks to remove it? I don't have a slide hammer; I was told that could be useful. Others have just successfully pryed it off with a prybar.
Thanks.
Thanks.
