Removing Extra Wiring with aftermarket ECU
garagefujimoto
Local Tire Destroyer
May 27, 2005
997
Calgary, Alberta, Canada
I have identified all the wires in the 1JZ-GTE engine harness.
I have also located and shown which wires are used/deleted with the EMS 4424 ECU.
I was able to remove around 50% of the wiring to the engine.
Please use at your own risk. Your results and situation may vary.
See attached .xls file. Hopefully this helps someone someday.
  • JZA70-001897.xls
