mkIIIman089 said:I don't think you need to waste money on Water Wetter, its about as effective as pink food dye from what I understand.
Mechanic on a race team I worked for, they used to run it but even running a redline sposorship; they switched to this: http://www.pro-blend.com/coolsys.htmlanternman said:Where did you learn this?
JustAnotherVictim said:Am I mistaken or is the coolant mainly used to help prevent rust from forming inside the cooling passages?
jdub said:I know from personal experience that the Red Line WW doesn't like Toyota coolant. Got crud in my overflow res and had to flush the motor. I've read it doesn't play well with other coolants as well. Using it with straight water is fine...it may or may not work with the coolant you're using.
