redline rear diff weight?
Jan 21, 2008
74
san francisco
Sup my fellow supra brothers,
im about to change the rear diff fluids on my 89 turbo mk3 5 speed. im going to choose redline but what weight do i use? tried searching and nothing poped up. thanks for your guys time. P.s. how many quarts will i need?
SupraRzTT
68
BC
If i remember correctly, its API-GL5 Hypoid Gear oil for LSD 75w 90. Drain an fill should be under 1.5litres.
Someone correct me if im wrong.
te72
Classifieds Moderator
6,626
10
WHYoming
1.3 liters last I checked. Make sure your fill bolt is removed FIRST, in case it's stuck, you don't want to drain it and THEN find that out. ;)
te72
6,626
10
WHYoming
airhead04;1788268 said:
Ahh, I believe you are right, thanks for correcting me. :)
GrimJack;1788280 said:
Also, I'll point out that Ford fluid appears to work better than Redline in the diff. I keep the transmission full of Redline, the diff full of Ford, and the engine full of Castrol.
You forgot the vegetable oil in the driver... :p
