Hello everyone,
So I recently acquired a built 7mgte.
Has:
A larger turbo (not sure about the specs at the moment)
Adjustable cam sprockets/gears
Bigger injectors (not sure on the cc but they're definitely not stock)
I haven't pulled off the valve covers yet to see what the camshafts look like.
I have made a deal with a buddy of mine that I pick up this motor from him, which he has no background knowledge of the motor and i will perform a leak down test on it. If everything checks out okay, I will then pay him for the motor. (he acquired this from a running parts car)
My question is:
Would I be able to slap on a stock CT26 and stock cam sprockets,injectors and run the motor on a stock ecu with no problems?
What if the camshafts are aftermarket, would this affect the performance of the engine with stock turbo, stock injectors, stock cam sprockets?
any other tests that should be performed?
Before anyone bashes on me, I want to put out there that my reasoning for wanting to do this is to get my supra back up and running.
My supra has been registered on NON-OP and will need to be smoked.
Any help is appreciated.
Has:
My question is:
