Reason for slight heater core flow?
CyFi6
Aliens.
Oct 11, 2007
2,972
Phoenix
www.google.com
Well I was thinking about throwing a manual shut off valve for the heater core into my truck for the summertime just to keep any chance of extra heat out of the cab. I remember that in the Supra (and probably other vehicles) the heater control valve never shuts off coolant flow 100%, and leaves a small opening for coolant to trickle through at all times, even with max AC on. I always wondered why exactly this was needed, and if anything can/will be damaged if heater core flow were completely halted. Only thing I can really even imagine would be that stagnant coolant in the heater core could somehow speed corrosion, but that is kind of far fetched and I don't have any evidence for the reasoning, just a pure guess.
Think it's more a flow thing so heat doesn't build up in any one spot more than another or create a wall with it no where to go.
I'd just leave it. It's extra cooling capacity.
te72
Classifieds Moderator
6,626
10
WHYoming
It's also in Arizona, where any additional heat in the cabin is quite unnecessary. :p
I personally never worried about it, if your AC is working well, you shouldn't even notice it. Tint your windows if you haven't already, I know of a really good place in Glendale that has done 3 of my cars now...
SupraPieces;1795939 said:
it was probably made that way so that you wouldn't have stagnant water sitting in your heater core and rot it out... flow=healthy
"should" be a coolant mix so there's little chance of it "rotting" more a case of it reduces the chances of an air pocket forming.
