I completed my build a few months ago, and when I went to prime the oiling system and turbo I found two large oil leaks. First ended up being the threaded plug behind the flywheel (already fixed) then I found a leak in the front. It is leaking from the rear timing cover (front cover). I'm guessing it's either the the threaded plug behind the cover just as it was in the rear or the cover gasket itself...
Now the question...
Is there anyway to get around pulling the engine to fix this? With this cover being sandwiched between the head and the oil pan is this going to be the only way? Would it be possible to loosen the head enough to lift it slightly to remove the cover without hurting the seal of the hg or the oil pan for that matter?
By the way I am using ARP studs and a MHG.
Any help would be much appreciated guys, thanks!
Now the question...
