Rear Brake Upgrade
wesbeech
Beech Performance Motorsports
Feb 26, 2006
1,022
Akron Ohio
I was wonderign what is avaible for a rear brake upgrade that you can still fit 15 inch drag rims over. I wasnt sure what calipers from other cars or kits or anything like that, that can clear a 15.
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
are your fronts already upgraded? rears arent usually upgraded mainly b/c it unbalances the brake system - or so people tell me ~ :)
wesbeech
Feb 26, 2006
1,022
Akron Ohio
Im working on my fronts now 13 or 14 inch rotors and 4 pot wilwood calipers
wesbeech
Feb 26, 2006
1,022
Akron Ohio
KeithH said:
Give ArizonaPerformance a looksee - they've got a nice rear setup availble that will go with this wilwood fronts.
But you lose your parking brake and i dont think 15 will fit under there.
7Mboost
7M Powered
Aug 15, 2006
2,201
Gainesville, FL
Maybe the mkiv rear brakes will fit (your wheels)? They fit the mk3 with a little modification, it'll come up in search if interested in this.
wesbeech
Feb 26, 2006
1,022
Akron Ohio
Thats what i was looking at was mk4 tt rear calipers do you know any one who has done it?
Red7m
123
Hollidaysburg PA
How does the na MKIV rear brakes compare to the MKIII rear breaks? If they are still an upgrade that may be a choice and they will fit with a set of 15in drag wheels.
TurboStreetCar
Formerly Nosechunks
Feb 25, 2006
2,779
13
Long Island, Ny
Doesn't look like they'll fit 15's because they say they wont fit the stock sawblade thats a 16.
I wonder how they perform compared to stock aswell. seems like a nice cheap easy upgrade if they perform well.
Adjuster
Your best bet would be a brake system designed for NASCAR rims.. They are 15" IIRC, and the way they got better brakes unside the smaller rims was by going with thicker rotors with more vanes to disperse as much heat as possible. (Also larger calipers and pads..)
Wilwood has many options for 12x1.38 heavy rotors with lots of vanes, and either 4 or 6 piston calipers that should fit inside of a 15" drag rim.
However, if your just going to be drag racing, the stock brakes do not suck that much. (They will stop you just fine once or twice in my opinion between cool down periods...) Especially the rear brakes in this condition.
Where I think the front and rear upgrade really plays out is when you use them on a track, autocross or just heavy street running around, and stop from high speeds mulitiple times in say 5 min or less from 140mph or more down to zero or just a few mph... Then the stock setup can't handle the heat dispersion needs, and they fail/fade.
My brakes will not fit 15" rims. (Heck, both rotors are 14" by themselves, and I've yet to find a caliper that mounts up that thin..)
I suppose you could try reverse mount brakes like Buel uses on his front motorcycle wheel, but I've never seen a viable car version of that design. (The rotor is mounted to the wheel, and the caliper is mounted to the hub/fork from inside the rotor.. v/s over the outside of it... ) Would be no fun to change a wheel.. You'd have to pull the caliper first.
