Rattle from under the car after driving around?
modmonster2008
mod crazy yo!
Sep 9, 2008
1,051
Seattle, WA
Ok so my car has been acting up lately after the head gasket replacement, when you fire it up it sounds fine, but after the engine warms up and i drive it around the block, i park it and something sounds like its ratting under the car, i tried fixing up the exhaust already, all the brackets under are tight, i just dont know what is causing it, sounds like its related to the engine/transmission but i hope not, anyone know how i can fix this? If im lucky ill try posting a video if it but ill see
Bill UK
90 Supra Turbo 14 psi
Aug 11, 2006
56
UK
I had the same problem after pulling my engine and re-fitting it, turned out to be the second cat knocking on the transmission tunnel. It’s a bit of a tight squeeze under there on the passenger side. (US model)
CRE
7M-GE + MAFT Pro + T = :D
Oct 24, 2005
3,485
Denver, CO
Chock the wheels and use a stethoscope with a long probe to track it down. If you don't have a steth use a long dowel, something long enough so you don't have to get under the car is HIGHLY advised. Have some else help to ensure the car doesn't move and to assist if something were to happen.
modmonster2008
mod crazy yo!
Sep 9, 2008
1,051
Seattle, WA
well i drove it around the block and once i parked it in the garage something starts rattling but when i raised it up on the hydraulic jack i cant point out where the noise is coming from, it just stops after...
CRE
Oct 24, 2005
3,485
Denver, CO
Yeah, I kinda figured. Hence the suggestion that you employ a tool designed for diagnosing machinery and locating sounds.... or just a big stick.
You trying to build the...
suspense? :icon_razz
Stops after what? Help me help you. (<---My high school guidance counselor used to love saying that. I hated that guy.)
Does the sound change when the clutch is either engaged or disengaged?
dumbo
1,913
Albera, Too Far North
it sounds like mine did when the tin guard that covers the steering shaft rattled against the intake manifold, it wouldn't hurt to check that out..mine was bad when the car was idling really lean.
if it is just bend it
cuel
1,536
Baytown, Texas
Sounds like a torque converter bolt to me as well. My exhaust used to rattle against the subframe for the rear pumpkin, and wuold kinda sound like that as well.
