radiator seem credible?
Same cheap chinese radiator more than likely made by the same chinese maker as the intercoolers all over ebay...
Personally, I don't like it because you have to fabricate top mounts for it, and it looks cheap...
IwantMKIII
WVU MAEngineering
Jun 12, 2007
2,477
Perkasie, PA
if this is for upgrading, GL, looks like a pain as there are no mounts as poodles mentioned. If its for replacement as your stocker is bad i have a nearly new stock oem replacement for sale if you're interested.
supraman74
I bought it SUPPED up
Apr 26, 2007
89
Iowa
Top mounts, who needs those....
Side mounts ftmfw :evil2:
Looks cheap, hope your side mounts are insulated, and you need a fan shroud if you want the fan to do anything...
supraman74
Apr 26, 2007
89
Iowa
It was cheap, side mounts are well insulated.
The Stock rad needs a shroud, this dont.
100 degrees today and my temp didnt go above 190.
IwantMKIII
WVU MAEngineering
Jun 12, 2007
2,477
Perkasie, PA
personally i have fluidyne. The most costly i know of but works well. Just as a warning....
THESE THINGS GET HOT! They will burn you nearly instantly, i have numerous scars/burn marks to prove it, one is still healing actually.
Wrong.
A fan without a shroud will suck air from the tips and around the radiator instead of THROUGH it.
I don't care what your temps where, it just means the radiator was working as an effective passive cooler/heatsink. Get in stop and go traffic and you will heatsoak it eventually and overheat.
I have a Koyo with custom shroud mounts for 7M fan shroud.
IwantMKIII
WVU MAEngineering
Jun 12, 2007
2,477
Perkasie, PA
Poodles;1094162 said:
Wrong.
disagree. While i'd like to have a fan shroud in traffic, its not a necessety with the right cooling capacity. Ive used the fluidyne for over a year now in all types of climates primarily in high traffic areas, no overheating, however did run a bit hot around 205-210*. Last summer i didn't even have a T-stat (i didn't realize it at the time) so my rad was constantly heat soaked.
ROFLMAO go price a PWR ;)
Clied
Wangan Supra
Jun 8, 2006
367
NorCal
Aren't the GodSpeed radiators better then these?
And I think there around the same price.
I always wanted a PWR radiator though...
jetjock
creepy-ass cracka
9,439
IwantMKIII;1094168 said:
....its not a necessety with the right cooling capacity. Ive used the fluidyne for over a year now in all types of climates primarily in high traffic areas, no overheating, however did run a bit hot around 205-210*. Last summer i didn't even have a T-stat (i didn't realize it at the time) so my rad was constantly heat soaked.
That's some funny shit right there. Seriously...do you actually think about what you post?
supraguy@aol
Well-Known Member
Dec 30, 2005
4,283
77
Atlanta
I have a CSR aluminum rad, and It works great. It's shaped exactly like a stock unit, but is a 2 row unit made completely of aluminum, so it's a compromise between stock and high performance(~PWR) design. It's also at a middle price- I paid $230. If I had to buy off of Ebay, I'd prolly give the Haste a try, though is also probably a clone of the Koyo or something.
Oops- It's been so long since I got it- I forgot, it's a CSF radiator, and I paid closer to $300
jetjock
creepy-ass cracka
9,439
Oh I don't doubt it's true. The funny part is you preach about having the "right cooling capacity" and advocate the Fluidyne (even claiming it "works well") then go on to conclusively demonstrate your cooling system has zero excess capacity. Forgive me for finding that humorous but come on, most people couldn't make that kind of stuff up if they tried...
IwantMKIII
WVU MAEngineering
Jun 12, 2007
2,477
Perkasie, PA
TBO, im not sure what you mean by "zero excess capacity". What i said is from experience, period.
