just finished the 1jz swap and after i started the car i can see it dripping from the bottom, drianed it and left the cap on so i could hear were its leaking from, heard it at the top left side of the radiator was smashed in alittle on the vents. i am using the hydro fan as well
can this be fixxed? (just untill i go with the 2jz water pump) i have a working 87 radiator and fan shroud.
do i have to use the hydro fan radiator or is there a replacement for it?
