rack and pinion strut?
SRZMK3
so when i drive straight.. sometimes i feel a thump and the steering wheel moves. i check all of my balljoints and suspension stuff.. those are great no movement, but when i check my rack and pinion thetie rod ends are nice and tight but theres this strut thing that goes across the front of the rack, that is very loose and makes the noise i hear when i push it up and down... what is this strut and how do i tighten it?
Not unless it needs replacing, if it's just the damper buy some rubbers from Toyota.
Get someone to jiggle the steering wheel while you watch the steering shaft, uni joints and rack ends for play.
