Racing Jacks
supra1642
113
Michigan
ok i was at harbor freight earlier and i saw some nice racing jacks but they say the limit is 3000 lbs. will this be able to lift the supra without any trouble or do they sell higher capacity ones and where? thanks for the help in advance.
My whole car only weighs 3700 pounds and you're not picking up the whole car at one time so it should work, but I would want at least a two ton jack if they have one.
Doward
4,245
Alachua, FL
One of the Aluminum ones? I had one fall apart in 2 years. I was disappointed by that.
I will say this though - it was great while it lasted!
Kckazdude
1,239
Memphis, TN
They are nice pit jacks to take to the track with you. After that get a real jack that will hold up. As Doward has already pointed out, they dont last long.
supra1642
113
Michigan
yes it was aluminum and i don't track my car do to the fact there aren't any close to me. do you guys/gals know of any good places that sell 2 ton racing jacks for a decent price. the one i was looking at was 3000lbs capacity for $130.00. i haven't googled it yet, just wondering if anyone could recommend a place.
You HAVE to do maintenance on those jacks...
You have to retighten everything pretty often as they come loose. Or use loctite...
IJ.;975878 said:
I bought one ages ago then returned it as it wouldn't fit under my car ;)
Gravity and lowered suspension isn't on Fatty's side.
I looked at low profile jacks a couple days ago and the Craftsman is $199.00
SupraMaster
Pure Street Racing
Mar 24, 2008
204
Washington
www.facebook.com
Hence my stock suspension.
You should be able to find a local auto parts dealer that will sell you something cheap, or look in your local paper. People sell this kind of crap all the time.
figgie
Twin Cities, Minnesot-ah
i have the craftsman aluminum jack. The 2 ton version. That thing is low enough to get under a lowered supra!
If taht does not work, do what the WRC teams do. Mini ramps to lift the car enough to get a jack under there.
89whitepkg
I hate rust !
Mar 7, 2006
121
Lexington, KY
I have a beast of a jack, and there is no way it will fit under my car, so I have two of the little spare jacks that came with the car that I put on each side and lift it up just enough to get my jack under. This take a little bit longer but to me it's worth it . I had a harbor freight jack and it busted quickly. Mine now is a lowes kobalt jack, I love it.
sethron71
Authorized Vendor
Jul 19, 2005
871
Las Vegas, NV
www.SethIngham.com
Bought one from Schucks a couple years ago, $100 with 2 jack stands. Works great and is a quick pump jack, like 4 pumps to max height! Really not bad quality for the price. Bought it as a temporary and then just kept using it and still using it!
HTH,
Seth
Keros
Canadian Bacon
Mar 16, 2007
825
Calgary
Michelin 3½-ton Speedy Lift Jack, is what I have... got it for $105. The thing is rediculously heavy, but I'm pretty sure you could drop a truck on it and the truck would break. ~5" min hieght, 22" max, more than enough for most supras.
KpSupra
Trussville, Al.
Make sure you look at lift height. Some of those jacks will only lift to 14". I would go with a minimum of 16" raise height and more if I could get it.
sneakypete
Regular Member
Jul 18, 2007
1,129
Central NJ
ive been through so many jacks. those racing jacks are great because they are convienient to use, but they brake easily. you have to check the oil on them often and have to tighten the swivel wheels basically every time you use it or else the ball bearing will come out. dont get an aluminum jack. go with steel.
WhtMa71
D0 W3RK
Apr 24, 2007
1,813
Macon, GA
Just put 4 race car jacks in your car that use nitrogen..
jk ive had the craftsman aluminum jack for going on 4 years now..worked great with my civici but once i started lifting the supra with it...it doesnt work so well anymore.
deabionni
The Lurker
Sep 16, 2007
431
Kalkaska, MI
I'm using the same jack, and it's the best jack I've ever owned. I picked mine up at Sam's Club for roughly $69.00
Keros
Canadian Bacon
Mar 16, 2007
825
Calgary
DOH! Nice deal at $70 :biglaugh:
We've been convinced it was the best $105 spent in the garage yet.
