R154/clutch question
Ya. I wouldnt fully tighten each one at a time tho. Do it in a few passes from each side.
suprajztwenty
369
corinth tx
yes, i just posted the link earlier
here incase youre looking at clutch section and not trans.
http://www.cygnusx1.net/Supra/Library/TSRM/MK3/manual.aspx?S=MT&P=4
tips, when youre ready to reinstall, line up your pressure plate/flywheel holes and mark the flywheel and pressure plate before going back in. because the mounting holes arent symmetrical, one or two are offset and can be frustrating if you dont get all the holes to match up... youll get to the last couple bolts and there wont be holes for them to go in.
other than that, use the moly on the clutch fork like the tsrm says
supraguy@aol
Well-Known Member
Dec 30, 2005
4,248
52
Atlanta
Does this help?
mattsplat72
is sofa king
Jan 17, 2006
1,738
Yup , that's it. Thanks for taking the picture. I see that Driftmotion sells a clutch alignment tool like for every other set up. Has anyone ever tried to do this like you would on a w58? Other then the shift fork why does the TSRM suggest that you do it this way?
supraguy@aol
Well-Known Member
Dec 30, 2005
4,248
52
Atlanta
There's no need for the alignment tool on the R154.
I don't even know why clutch kits contain them. I just got a Spec 2+ for mine, and it included the dumb thing.
I'm developing a small pile of alignment tools, lol. On our trannys, the input shaft IS the alignment tool.
