r154 attached to 2jz
shaggyskadude13
AAARRRGGGHH!!!!!
May 16, 2007
Rockledge, Florida
I know this question has probably been answered before but I searched and couldnt find anything. So here it is again. Which bell housing would you use to attach a r154 to 2jz for a manual tranny swap. Would the 1jz bell housing for a r154 work or would a w58 bellhousing off a 5 speed soarer work. Any help would be awesome.
-Brent
p5150
ASE and FAA A&P Certified
Central Idaho
I have heard some people say that a w58 would work, but I dont see how it could. However, I have never tried it...
I used a 1jz bell housing. If you try out a w58 and it works then more power to you.
Bigzavs
86.5 1JZ Single Turbo
Apr 21, 2005
2,267
Arlington, TX
^^ this man is most definitely correct
and wouldnt the w58 off of the MKIV n/a work? or is it different from the mkiii w58
Jeff Lange
Administrator
4,927
Sunnyvale, CA
jefflange.ca
Any W58 can be bolted to the 2JZ with the 2JZ-GE M/T bellhousing.
The MKIV N/A 2JZ-GE extension housing/shifter setup wouldn't work in a MKIII however (remote shifter bracket/linkage instead of direct into transmission).
