quick clutch question
supra8903
512
Latham, NY
Hello....
I have searched with no answer...
can you reuse 7m flywheel bolts, and should they be sealed so oil won't leak through, or is this only an issue with 1jz s
thanks
joe
BorHor
2JZ-GZE
Jan 10, 2006
6,181
San Jose, CA
I would get new ones because all that heat probably weakened them. As for sealing.. I think locktight should do the job.
5
by the TSRM, they are reusable...
but they're cheap, so get new ones.
You don't HAVE to seal them, but I use red loctite as I don't want them coming loose. I use an impact to remove them so it's not an issue...
gilberjj
Friend of Fast
Apr 14, 2006
661
Tacoma, WA
considering arp flywheel bolts are $35ish dollars, there is no reason to risk it. there are some ppl that have broken the bolts, and that will ruin your day no doubt. just do it and never worry about it again
5
I couldn't find the part number when I needed it, so I have new stock boltsd in mine...
The tranny will be swapped eventually anyways, so I'm not too worried about it...
Anyone know if there are ARP bolts for the PP to flywheel?
gilberjj
Friend of Fast
Apr 14, 2006
661
Tacoma, WA
i got them from driftmotion. they are the exact same bolts for the 1jz and 7m. only the 7m requires 5 or 6, while the 1jz requires like 8. so you end up with left over bolts
