Questions on the two vsv's under the intake
gaboonviper85
3,236
Northeast Philly
Question #
1. The vsv that controls the fuel pressure regulator...is it acceptable to remove this when using an afpr when performing bpu's? What are the possible negitive effects if removed?
2. The two vsv's have different part #'s but are they interchangeable? I've noticed that with no power to them, they route the same..
3. Does anybody have detailed pics of where and how exactly they mount under the intake?
Thanks for lookin!
bluepearl
326
pa.
As Radiod said, they mount to the lower intake bolts.
In some situations, Possible hard start hot if removed.
isnms
United States of America
Oklahoma
i80.photobucket.com
gaboonviper85;1465648 said:
Question #
Thanks for lookin!
2. The connectors are keyed, so not interchangeable
3. The FPU VSV mounts way up under the manifold on against the head in oem configuration. Jason T posted a pic. It's kind of difficult to see but read suprra_girl post and then you will be able to spot it.
http://www.supramania.com/forums/showthread.php?t=454
TurboStreetCar
Formerly Nosechunks
Feb 25, 2006
2,779
13
Long Island, Ny
RotaryHead;1465726 said:
the one on the right is for the egr and you still need the other one hooked up to control fuel pressure while you drive
It only changes fuel pressure on startup and Jdub stated. Does nothing while driving.
IwantMKIII
WVU MAEngineering
Jun 12, 2007
2,480
Perkasie, PA
jdub;1466426 said:
To answer your 1st questions Gaboon, the purpose of the FP up VSV is to increase FP when coolant temps are hot:
http://www.cygnusx1.net/supra/Library/TSRM/MK3/manual.aspx?S=FI&P=116
The VSV opens to atmosphere (same as if you disconnected the vac line) to increase FP for a hot start. The issue you may have is a difficult/no-start on a hot summer day.
I was under the impression the 'venting' function of this vsv was to eliminate fuel vapors and get rid of the air pockets, not necessarily just to increase FP.
Your "impression" is incorrect. Look at the routing of the vac lines to the VSV...how would it get rid of fuel vapor directly by "venting"?
(Hint: it's impossible)
It works exactly as I stated, the VSV vents to atmosphere and causes the FPR to raise FP...exactly the same as if you disconnect the vac line at the FPR for the TSRM FP tests. Any vapor or air pockets in the fuel rail would be purged (more quickly w/ increased FP) through the FPR to the return line to the tank.
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
Well, in a roundabout kind of way. The increased fuel pressure purges the fuel rail, sending any fuel that's heat soaked back to the tank faster than it would otherwise.
MA70_Powa
Boost Addict
Jun 17, 2007
180
Tasmania
I havent had mine in there since day one of my engine swap (they vanished off my N/A motor :() and I've had no isssues whatsoever. Even on hot days -well, hot for here. probably not as hot as what you US boys can get.
gaboonviper85
3,236
Northeast Philly
After very close inspection....the connectors are keyed but they are the exact same...i took all the spare vsv's I had (4) with all different mounting brackets and each one could fit front or back:-(
