question about tow hooks
born2drv
1,199
Burbank, CA
just curious........... but if these tow hooks are removed to make way for a bigger IC .... what does the tow truck driver latch on to in order to hoist your car up??
blackout_89t
King of the roll
Apr 25, 2005
488
Toronto
it is a rwd car, usually gets towed from the rear. In most cases though the front end will be to low having it lifted from the rear, so request a flatbed.
B
Boostaddctn
Guest
The control arms, if you don't have the tow hook... aight peace :chicken:
N
NDBoost
Guest
Jeff Lange said:
In a manual tranny, that's usually not a problem, if it's in neutral, but with an auto tranny, that's a bad idea with a RWD car.
werd, which is why i had my car on a 4 wheel trailer from cali to az.
just request a flat bed, less chance of something bad happening
Joel W.
Just A Jedi
Nov 7, 2005
1,561
Washington
As an ex tow truck driver, ill add that the tow hooks are used to secure the car when it was being imported overseas, , and are also designed for winching or off road recovery and not for towing. most trucks grab the wheels when lifting...Flatbeds are the exception,
ALSO: flatbeds have issues as well on long trips, as the wheels are not turning and the bearings are rocking back and forth on one spot of the bearring causing pitting. they used to haul cars on trains untill they realized that all of the cars needed new bearings installed after the trip across country..
whudafux
Formerly dcrusupra
Jan 5, 2006
1,034
Cullowhee, NC
Or I used the tow hooks on the back of the supra to pull down a tree after hurricane wilma. Also had to go mudding a little bit to get around the trees, fences, etc. that was in the road. Power was also gone for a week, thank god it was cold out until the power came back on lol. Kinda fun getting hurricanes.
N
NDBoost
Guest
the NA pulled a tree? i thought they struggled hauling a carload of american females...
