Dan_Gyoba;1957416 said:Well, the Neo adjusts the AFM output, so... Sort of. You can't get rid of it, and I would advise against making large adjustments to the AFM output with stock injectors, but the 7M is known to run very rich, so there's probably room to raise FCO by a bit. I would not do so without supporting data from a wideband. This could be done with a dyno tune, or to have a wideband data logger, but you're begging for trouble raiding FCO without it.
Never use the FCD unless you like blowing up engines. Going over 500 RWHP is going to require a standalone. And that's assuming your fuel system, suspension, brakes, driveline, and engine internals are up to the task of putting that kind of power down.SupraTurbo_MK3;1957557 said:Well I'm installing a GT3782 Garrett VNT turbo and I'm aiming for at least 500rwhp so I plan running about 20-25psi and this is my third MK3 so even with everything you mentioned I still have a long way to go and very familiar with most of what I need to do, thanks to guys like you on this site......So I have to get a fuel cut defender or go stand alone is what your saying?
The reason I want to use the Apexi Neo is because I can tune the turbo with it.
Another MkIII;1957559 said:Never use the FCD unless you like blowing up engines. Going over 500 RWHP is going to require a standalone. And that's assuming your fuel system, suspension, brakes, driveline, and engine internals are up to the task of putting that kind of power down.
Will I be able to tune the VNT turbo with a standalone?
Dan_Gyoba;1957560 said:Well, it may be possible for 500RWHP without a standalone, but you'll probably spend as much without. FCD is just a bad idea. Period.
With the Neo and a Lexus AFM, you should be able to run 680cc fuel injectors, which is enough fuel to get you there. (The Neo by itself isn't enough, nor is the AFM.) Instead of the Lexus AFM, you could probably use a MAF translator for a GM MAF, or go MAFT-Pro or other MAP solution.
Not sure how the VNT turbo is going to work without substantial electronics to back it up, which probably also means standalone, assuming that there are standalones which understand them. Also, I understand that most variable turbos are diesel applications, and that they don't handle high performance gasoline EGTs all that well yet. That information may be outdated, though.
There is a LOT of work to getting a 3L engine to 500WHP. Doing it wrong is building an expensive boat anchor, doesn't matter if you're starting from a 7M, 2JZ, BMW, or whatever. That kind of power from that displacement means that there's little margin for error, and if you do something wrong, it's going to go boom.
SupraTurbo_MK3;1957563 said:Well I plan on removing the afm so looks like I will have to go standalone, I was assuming I could remove it after installing Apexi neo
Trent;1957630 said:No the Neo works with the AFM, it does not take the place of the AFM. It intercepts the AFM signal and changes it so the factory ECU will pull fuel out or add it depending on what adjustments you are making. Without the AFM signal, a Neo isn't worth much
I was one of those back in 2004 and made over 500rwhp on the factory ECU and a piggyback (original MAP-ECU). Made 540rwhp actually. Totally stock bottom end and head as well. It didn't last very long that way. It made it a few months at that power level and cracked the #1 piston in a number of pieces. That same motor made 440rwhp on a prior turbo setup with MAP-ECU and stock ECU and ran like a bat outta hell for several years that way. But of course I got greedy and wanted more.
The setup I have now is using the Lexus AFM and Apexi Neo and I will stick to 425-450rwhp and leave it at that. I don't want to go the standalone route and just want something safely tuned and not running on the edge of catastrophe. I wouldn't go much further than that with a stock ECU.
